Hello all users,
I’m trying to solve for BN particle in water so this is the numbering of my
atoms:1-O
2-H
3-B
4-N
So I’m using this pair_coeff commands to use SPC/E for water, Tersoff for B
and N, and Lennard-Jones for cross relations. I carefully read the manual
about how to use pair_style hybrid command but the results are not as
expected, therefore I’m trying to understand the problem if it is in
potential definition or in post-processing. Do you think is there a problem
with these force field definitions? I understand that it should be
overwritten if we define the same type of atoms more than once in pair_coeff
so I guess once the tersoff is defined for B and N, water parameters and
cross relations should get the new values in the following pair_coeff
commands right? I will appreciate if you give me a couple of suggestions if
I am doing something wrong or how can I get better force field definition
for this problem? Thank you for your attention.pair_style hybrid lj/cut/coul/long tersoff coul/long 9.0
pair_coeff * * tersoff slotmant.tersoff NULL NULL B N
pair_coeff 1 1 lj/cut/coul/long 0.1533 3.166
pair_coeff 2 2 lj/cut/coul/long 0 0
pair_coeff 1 2 none
this one is *wrong*. you may not have lj interactions between H and O,
but you have to have coulomb.
you could have either:
pair_coeff 1 2 coul/long
pair_coeff 2 2 coul/long
or:
pair_coeff 1*2 2 lj/cut/coul/long 0 0
pair_coeff 1 3 lj/cut/coul/long 0.12 3.31
pair_coeff 1 4 lj/cut/coul/long 0.149 3.414
pair_coeff 2 3 none
pair_coeff 2 4 none
i don't understand this segment either. do you have coulomb
interaction between O and B or N? or only lj? and how about the
charges on H atoms?
