The example in the material about lammps_spparks
Dear all users,
I try to use lammps_spparks to simulate the grain growth, but I can not find the related example in the real world. The web mentions that " coupling of LAMMPS and SPPARKS, to couple a kinetic Monte Carlo model for grain growth using MD to calculate strain induced across grain boundaries",but I can not find the knowledge of material to prove that the force created by the interatomic potential function of lammps impact grain growth of spparks.
Please help me if you have the related paper.
This is a LAMMPS software package related mail-list and not an educational advice service I am afraid.
With best wishes,
Anna
That is just a simple demonstration problem to show
that you can couple LAMMPS to another code, the kMC
code SPPARKS in this case. To do a real problem,
you would have to worry more about the physics
of grain growtth and what values to exchange between
the 2 codes. But the software coupling mechanism would remain
the same. And a stress field does indeed induce
changes in grain growth.
Thank you for your explanation. Now I understand the reason of producing strain, but don not know how the strain influence grain growth. And I notice that in“potts/strain” module its probability is 1/(1+strain) when dE <= 0 and exp(-dE/kT*) when dE > 0, but it is different with the MC grain growth algorithm. Its probability is 1 when dE <= 0 and exp(-dQ/RT) when dE > 0( B. RADHAKRISHNAN and T. ZACHARIA: Simulation of Curvature-Driven Grain Growth by Using a Modified Monte Carlo Algorithm). For example, in the algorithm, when dE <= 0,it will transformation successfully, but it may be failed in “potts/strain” module. So for “potts/strain” could you give me some suggestion?
Please help me if you have the answer.
You’re asking good Qs, but the answers are up to you.
Again, the provided example is meant to be a simple
demo of how to couple 2 codes, one of them being LAMMPS.
It is not meant to be an accurate model of strain-induced
grain growth. If you want an accurate model, then build
on and extend the provided example. That’s a job for you,
not for the LAMMPS mail list.
