Dear Sir or Mad,
Thanks for your reading.
I do not know whether I can calculate the thermal conductivity using ReaxFF in LAMMPS.
I have a problem about the Al2O3’s thermal conductivity using ReaxFF. We can not calculate the thermal conductivity in C++ version, because " pair_style reax/c command cannot yet compute per-atom energy or stress". But, Fortran version don’t state this. So, I used fortran version reax to calculate the Al2O3’s thermal conductivity with EMD(Green-Kubo) method. But, I obtained the negative thermal conductivity, and I do not know the cause.
I state those:
- Before calculating the thermal conductivity, we must calculate the per-atom energy and stress, in order to calculate the heat current;
- The Al-O potention maybe not the cause: I obtained it from Adri. And I using other Al-O reax potention, from “potention” document, also obtained the negative thermal conducitity;
3)Green-Kubo method maybe not the reason: I use it calculate the Si’s thermal conductivity, and the result is all right.
I guess two causes:
- The reax force field is not suit to calculate the thermal conductivity; (but I do not believe it)
- The per-atom energy or stress do not accuracy using LAMMPS of fortran version resulting in the problem.
I want to eliminate the code reason, because C++ can not calculate the per-atom property, and maybe Fortran calculate is wrong.
Maybe there are other causes! Could give me some suggestions about this problem!
Best wishes,
Xiong
