Recently I tried to build gpu version of lammps. Following the
instructions of the Manual, I have built the libgpu.a and
nvc_get_devices successfully with openmpi. However, when I execute the
nvc_get_devices, the following error message appears:
./nvc_get_devices
Cuda driver error 100 in call at file './geryon/nvd_device.h' in line 232.
application called MPI_Abort(comm=0x44000000, -1) - process 0
In: PMI_Abort(-1, application called MPI_Abort(comm=0x44000000, -1) - process 0)
I changed to mpich and the following error appears:
./nvc_get_devices
Attempting to use an MPI routine before initializing MPICH
Since there is libgpu.so have generated, I compiled the lammps and got
the final executable lammps version. However, when I execute it, the
same error message shown above is observed. When I looked into the 232
line of './geryon/nvd_device.h', I just could not figure out what is
wrong. Could anyone give me some advices? Thank you very much.
./nvc_get_devices
process 0)
which tells you, that your GPU setup doesn't work,
or you compiled the GPU library for a GPU architecture
different from the one that you have.
./nvc_get_devices
since the error message is GPU related, how should this be
corrected by changing the MPI library? that seems to be a
*very* strange way to solve a problem.
have you been able to run any other GPU software?
the compilation of a library says nothing about being able to
execute GPU code. if you cannot run nvc_get_device, then you
have to fix this first.
What axel said is correct. If nvc_get _devices doesn't work, this is typically a problem outside of lammps. This error means that no CUDA device can be found on your system. I would recommend starting with the CUDA sdk and nvidia forums to get this solved. Good luck. - Mike
