I have a question regarding the returned integer in the extract method of pairs , specifically the variable “dim” in
void *PairLJCharmmCoulLong::extract(const char *str, int &dim).
For this pair the returned value of dim is 2 for the lj parameters and 0 for the cut offs (as shown below).
—pasted from pair_lj_charmm_coul_long.cpp of lammps’ source code:
dim = 2;
if (strcmp(str,“lj14_1”) == 0) return (void *) lj14_1;
if (strcmp(str,“lj14_2”) == 0) return (void *) lj14_2;
if (strcmp(str,“lj14_3”) == 0) return (void *) lj14_3;
if (strcmp(str,“lj14_4”) == 0) return (void *) lj14_4;
dim = 0;
if (strcmp(str,“implicit”) == 0) return (void *) &implicit;
if (strcmp(str,“cut_coul”) == 0) return (void *) &cut_coul;
return NULL;
I examined some functions (such as ppm.cpp) that called the extract( some_char*,dim ) method.
—pasted from pppm.cpp of lammps’ source code:
int itmp = 0;
double *p_cutoff = (double *) force->pair->extract(“cut_coul”,itmp);
if (p_cutoff == NULL)
error->all(FLERR,“KSpace style is incompatible with Pair style”);
cutoff = *p_cutoff;
In above pasted code the variable &dim from the extract of the pair is stored in itmp however it seems to me that the pppm does not use the itmp any further.
I haven’ yet figured out the &dim variable returned from the extract() of the pairs, and my question is:
For a ‘new/custom’ defined/codded pair-wise additive pair_style (call it:“PairACustomBuiltPairCutCoulLong”) should the returned int at &dim from the extract method of this pairstyle:
void *PairACustomBuiltPairCutCoulLong::extract(const char *str, int &dim){…}
be dim=2 for the van der Waals parameters and dim=0 for cut offs? Or what other values should have?
Thank you.
