thank you for your kind responses. I’ve got some comments on my problem.
- As the manual indicates, dpd/tstat invokes pairwise interactions which are equivalent to the non-conservative portion of the DPD force field. I think this is not suitable for my model.
- I found the fix temp/rescale command can rescale the system temperature well, but I am not sure if this command will cause inappropriate DPD interactions for my model?
- I found from literatures that many people use NVT ensemble in their simulations. However, as "pair_style dpd +fix nvt " can not be used because of the repeated thermostats and “pair_style dpd/tstat + fix nvt” do not consider Fc, I do not know which command can be used to conduct “dpd + NVT” simulation. Hope you can give me some suggestions based on your experience. Thanks!
zhikun
thank you for your kind responses. I've got some comments on my problem.
1) As the manual indicates, dpd/tstat invokes pairwise interactions which
2) I found the fix temp/rescale command can rescale the system temperature
no. fix temp/rescale will only mask the real problem. your simulation
has to conserve energy with pair style dpd and fix nve. if it doesn't,
something is wrong.
3) I found from literatures that many people use NVT ensemble in their
of the repeated thermostats and "pair_style dpd/tstat + fix nvt" do not
consider Fc, I do not know which command can be used to conduct "dpd + NVT"
dpd includes the thermostat, so fix nve is adequate. technically, i
don't think that using the term NVT ensemble is a correct for DPD in
general, but that is a different issue. as steve pointed out, there
are more complex DPD models in the USER-DPD package, but your problem
seems to be a very fundamental one. i believe that you will first need
to debug and identify what is causing the energy issue. but without a
data file, that is impossible to tell.
