I get an error when I run the following in file on lammps-23Jun2022, but running it on lammps-3Mar2020 with the same in file doesn’t produce this error? What I want to know is, is this bug generated with the version upgrade or some other issue? And how can I fix this? Thanks for the valuable input.
boundary p p s
atom_style atomic
neighbor 2.0 bin
neigh_modify every 1 delay 5 check yes
region box block -180.75 180.75 -180.75 180.75 -361.5 361.5 units box
create_box 3 box
lattice fcc 3.615
create_atoms 1 box
region cy1 cylinder z 0 0 48 -100 100 units lattice
delete_atoms region cy1
create_atoms 2 region cy1
region zhu cylinder z 0 0 45 -100 100 units lattice
delete_atoms region zhu
create_atoms 3 region zhu
group zhu region zhu
group cy region cy1
group cons subtract cy zhu
group yueshu subtract all cy
mass 1 64
mass 2 64
mass 3 64
write_data tongzhu.xyz
pair_style eam
pair_coeff * * Cu_u3.eam
thermo 1000
thermo_style custom step temp pe ke pxx pyy pzz lx ly lz
minimize 1.0e-12 1.0e-12 10000 10000
fix 1 all box/relax x 0 y 0 #xy 0
unfix 1
unfix 1
unfix 1
unfix 1
unfix 1
minimize 1.0e-13 1.0e-13 10000 10000
timestep 0.001
reset_timestep 0
velocity all create 300 99999 dist gaussian
fix re all npt temp 300 300 0.1 x 0 0 1 y 0 0 1
run 50000
unfix re
#fix hengwen yueshu nvt 300 300 0.1
#fix stable yueshu rigid single
#neigh_modify exclued group yueshu yueshu
velocity yueshu set 0 0 0
fix fixed yueshu setforce 0 0 0
compute T zhu temp
compute t cons temp
compute vcentro all centro/atom fcc
compute vpe all pe/atom
compute vcna all cna/atom 3.085764
#compute s zhu stress/atom NULL
#compute v zhu voronoi/atom
#variable stressx atom c_s[1]/c_v[1]/10000
#variable stressy atom c_s[2]/c_v[1]/10000
#variable stressz atom c_s[3]/c_v[1]/10000
#compute 1 zhu reduce/region film_layer ave v_stressx
#compute 2 zhu reduce/region film_layer ave v_stressy
#compute 3 zhu reduce/region film_layer ave v_stressz
thermo 1000
thermo_style custom step temp pe ke pxx pyy pzz lx ly lz c_T c_t #c_1 c_2 c_3
fix hengwen cons npt temp 300 300 0.1 x 0 0 1 y 0 0 1
fix_modify hengwen temp t
#variable x1 equal “xlo”
#variable x2 equal “xhi”
#variable y1 equal “ylo”
#variable y2 equal “yhi”
#variable z1 equal “zlo”
#variable z2 equal “zhi”
#region cub block {x1} {x2} {y1} {y2} {z1} {z2}
#group cub region cub
#group excess subtract all cub
velocity zhu create 300 98998 dist gaussian
fix w1 zhu npt temp 300 300 0.1 x 0 0 1 y 0 0 1
fix_modify w1 temp T
run 50000
error:
unfix re
compute T zhu temp
compute t cons temp
thermo 1000
WARNING: Temperature for fix modify is not for group all (…/fix_nh.cpp:1423)
run 50000
ERROR: Must not have multiple fixes change box parameter x (…/domain.cpp:168)
Last command: run 50000
