Hi everyone,
I am using LAMMPS to simulate a 2D LJ system recently. I have met a problem.
When I used boundary as "s s p", the whole system will rotate.
I had use the commands:
velocity all create ${temp} 76329 loop geom mom yes rot yes
fix 3 all enforce2d
fix 4 all momentum 1 angular
to zeroed the angular momentum.
If I set the boundary as "sf s p" or something like that, I will get the error of "lost atoms".
May anyone give some advice to make the system not rotate?
Thank you in advance.
regards,
Arthur
