Hi
I want to simulate thermal conductivity of a multi component system (such as Cu-Ar) by G-K method. But the result I have obtained is much higher than the actual result. The problem is I didnt subtract the partial entalpy term. Thats why I am getting error. I have read that, partial enthalpy term can be incorporated in heat/flux command like this:
compute flux all heat/flux myKE myPE myStress penthalpy …
but I am getting error in heat/flux command .
how can I get the thermal conductivity correctly for multi component system in LAAMPS.
Siyam
Hi
where did you read this? it cannot be in the LAMMPS documentation, as the syntax above is in conflict with the documentation at: https://lammps.sandia.gov/doc/compute_heat_flux.html
as you should. the authoritative source is the LAMMPS documentation and that does not know the syntax you are using.
the heat/flux syntax is wrong according to lammps documentation. so how can I get the thermal conductivity correctly for multi component system in LAMMPS. is there any way to subtract partial enthalpy term ?
you didn’t answer my question of where you found that unsupported syntax.
according to the examples/KAPPA folder, LAMMPS supports 5 different ways to compute thermal conductivity. i would expect that at least one of those methods would be applicable to your case, even if using compute heat/flux is not.
I have read about the syntax from the following link:
https://lammps.sandia.gov/threads/msg39318.html
As the email says, this is for a MODIFIED version of compute heat/flux.
