thermal conductivity of Silicon
Dear Users,
I am new user of LAMMPS. I was trying to get thermal conductivity of silicon(10X10X10) at room temperature (300K).The result I have got is 0.1832749825[W/mK].
whereas the experimental value at room temperature is around 150[W/mK]
I am giving bellow the script file and the output file. Please suggest me about that discrepancy.
Thanks & Regards
INPUT FILE
Sample LAMMPS input script for thermal conductivity of solid Ar
units real
log log.thermo
variable T equal 300
variable V equal vol
variable dt equal 1.0
variable p equal 2000 # correlation length
variable s equal 1 # sample interval
variable d equal $p*$s # dump interval
convert from LAMMPS real units to SI
variable kB equal 1.3806504e-23 # [J/K] Boltzmann
variable kCal2J equal 4186.0/6.02214e23
variable A2m equal 1.0e-10
variable fs2s equal 1.0e-15
variable convert equal {kCal2J}*{kCal2J}/{fs2s}/{A2m}
setup problem
lattice diamond 5.431020504 orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
region box block 0 10 0 10 0 10
create_box 1 box
create_atoms 1 box
mass 1 28.0855
pair_style sw
pair_coeff * * Si.sw Si
timestep ${dt}
thermo $d
equilibration and thermalization
velocity all create $T 102486 mom yes rot yes dist gaussian
fix NVT all nvt temp $T $T 10 drag 0.2
run 8000
thermal conductivity calculation, switch to NVE if desired
#unfix NVT
#fix NVE all nve
reset_timestep 0
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom virial
compute flux all heat/flux myKE myPE myStress
variable Jx equal c_flux[1]/vol
variable Jy equal c_flux[2]/vol
variable Jz equal c_flux[3]/vol
fix JJ all ave/correlate $s $p d & c_flux[1] c_flux[2] c_flux[3] type auto file J0Jt.dat ave running variable scale equal {convert}/${kB}/$T/$T/$V*s*{dt}
variable k11 equal trap(f_JJ[3]){scale} variable k22 equal trap(f_JJ[4])*{scale}
variable k33 equal trap(f_JJ[5])
${scale}
thermo_style custom step temp v_Jx v_Jy v_Jz v_k11 v_k22 v_k33
run 100000
variable k equal (v_k11+v_k22+v_k33)/3.0
variable ndens equal count(all)/vol
print “average conductivity: $k[W/mK] @ T K, {ndens} /A^3”
OUTPUT FILE
LAMMPS (12 Jun 2011)
Lattice spacing in x,y,z = 5.43102 5.43102 5.43102
Created orthogonal box = (0 0 0) to (54.3102 54.3102 54.3102)
1 by 1 by 1 processor grid
Created 8000 atoms
Setting up run …
Memory usage per processor = 3.88605 Mbytes
Step Temp E_pair E_mol TotEng Press
0 300 -34692.8 0 -27539.75 2039.4771
2000 298.54018 -25587.308 0 -18469.065 3881.0011
4000 297.88202 -25422.241 0 -18319.691 4330.0133
6000 298.48454 -25463.276 0 -18346.36 4251.9003
8000 303.52777 -25504.876 0 -18267.711 4351.6948
Loop time of 1083.56 on 1 procs for 8000 steps with 8000 atoms
Pair time () = 1076.47 (99.3454) Neigh time () = 2.71907 (0.250938)
Comm time () = 0.778279 (0.0718259) Outpt time () = 0.000267029 (2.46436e-05)
Other time (%) = 3.59513 (0.331787)
Nlocal: 8000 ave 8000 max 8000 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 6310 ave 6310 max 6310 min
Neighs: 0 ave 0 max 0 min
FullNghs: 314634 ave 314634 max 314634 min
Total # of neighbors = 314634
Ave neighs/atom = 39.3293
Neighbor list builds = 107
Dangerous builds = 0
Setting up run …
Memory usage per processor = 6.55825 Mbytes
Step Temp Jx Jy Jz k11 k22 k33
0 303.52777 2.5531227e-06 4.007608e-06 1.5116147e-06 0.00020301505 0.0005002134 7.1165101e-05
2000 296.0052 1.6294656e-07 8.4757968e-06 -1.3778724e-05 1.9181163 0.32243902 -0.16272834
4000 299.77155 -2.6721054e-06 -8.1760149e-06 -8.6290394e-06 0.6376134 0.0068575213 0.08948722
6000 297.37444 -2.4663349e-06 2.2979218e-06 8.0432749e-06 0.42809529 -0.10018507 0.11123582
8000 298.65918 7.0964745e-07 -2.3130065e-06 -7.7538574e-06 0.35707644 0.043425438 0.077682706
10000 303.08376 -5.0099107e-06 3.3658571e-06 -2.1141601e-06 0.23664915 0.28220569 0.095267134
96000 300.30057 8.0176056e-06 2.7098316e-06 -6.8740613e-06 0.20315033 0.22886874 0.12066023
98000 294.86472 8.4298057e-06 1.3330126e-06 4.315606e-06 0.20746175 0.22187796 0.12377436
100000 301.67178 1.492394e-05 8.880098e-06 -1.303326e-06 0.20294253 0.22140104 0.12548137
Loop time of 16198.2 on 1 procs for 100000 steps with 8000 atoms
Pair time () = 16022.6 (98.916) Neigh time () = 34.0301 (0.210086)
Comm time () = 10.1111 (0.0624215) Outpt time () = 0.0465102 (0.000287133)
Other time (%) = 131.394 (0.811167)
Nghost: 6254 ave 6254 max 6254 min
FullNghs: 314110 ave 314110 max 314110 min
Total # of neighbors = 314110
Ave neighs/atom = 39.2638
Neighbor list builds = 1340
average conductivity: 0.1832749825[W/mK] @ 300 K, 0.04993966903 /A^3
You're using real units, and the SW potential
files provided with LAMMPS are in metal
unts (see the SW doc page). Nothing about
your simulation will be correct in that case.
