thermal impulse command
Hello lammps users
Can some one please suggest me an appropriate command to impose an ultrafast thermal impulse on a layered material which will cause a rise in temperature.
thanks in anticipation.
Jakes
Hello lammps users
temperature.
http://lammps.sandia.gov/doc/velocity.html
it's even ​faster than ultrafast.​ it's instantaneous.
Of fix heat if you want to be a bit more gradual :slight_smile:
Thank you for your response.
I am using unit metal
I intent to pump a heat impulse of 0.00468 W on a layer of atoms for just 0.05 ps and observe their excitations. my time step is 0.0005 ps.
now converting to eV/ps I got 2921.0249779 eV/psec. below is a portion of my script
#excitations
fix 3 Phos heat 100 2921.024
variable Temperature equal temp
variable tEnrgy equal etotal
#fix 4 all ave/time 100 10 1000 v_Temperature v_tEnrgy file file1.dat
thermo 100
thermo_style custom step temp time etotal v_Temperature
unfix 3
and I seems not to get it right. please I will appreciate your comments.
