thermostating atoms in a region
Dear Niall:
Thank you very much for kindly answering my question. To make sure that I get your idea right and also help other users with similar questions, could you check if the following script is correct implementation of your idea?
region middle_region block x1 x2 INF INF INF INF units box
compute comp_mid midFluids temp/region middle_region
fix 1 all nve
fix controlT all temp/rescale 20 300 300 0.01 1.0
fix_modify controlT temp comp_mid
Thank you very much and happy holidays!
With best regards,
Nick
Re: [lammps-users] thermostating atoms in a region
Attachments: Message as HTML
You’re thinking along the right lines, but you need to use a fix_modify as well:
  1. Define a region which covers the bit of the box that you want to thermostat
  2. Use a fix command to set up the thermostatting you want (don’t worry about limiting it to a region just yet)
  3. Set up a compute temp/region to calculate the temperature in your region of interested
  4. Use fix_modify temp to associate that compute with the thermostatting fix.
So in your case, you need to use a fix_modify temp to associate your temp/region compute with your temp/rescale fix: fix_modify temp <temp/region compute ID> (http://lammps.sandia.gov/doc/fix_modify.html)
Niall
Nick,
If LAMMPS was a house it should have a sign on the fence reading:
"BEWARE OF TEMP/RESCALE"
Explanations on why using temp/rescale is a bad idea have been
repeatedly posted on this list. See for example Axel's response on:
http://lammps.sandia.gov/threads/msg33516.html
Use a Langevin thermostat instead. It is simple and will do the work
of controlling the temperature just fine.
Carlos
That script looks to me like it should work. You can set up a model system pretty quickly and use something like ave/spatial to generate a temperature profile and check.
Niall
