I use “mpirun -np 4 lmp_mpi -sf gpu -pk gpu 1” and that will launch 4 processes on cpu (seen by top ) each with 100% utilization and 4 processes on gpu (seen by nvidia-smi). That basically means four processes are sharing gpu.
I want to know if it is possible to have one process on cpu with 400% cpu utilization.
Regards,
Mahmood
yes, and this is a good thing. it increases GPU occupancy with most GPUs (you may need even more concurrent tasks for modern high-end GPUs) and parallelizes the parts of the calculation, that are not GPU accelerated.
no. besides, higher utilization doesn’t automatically result in better performance.
yes, and this is a good thing. it increases GPU occupancy with most GPUs (you may need even >more concurrent tasks for modern high-end GPUs) and parallelizes the parts of the calculation, that >are not GPU accelerated.
But the case for GPU is different from CPU. Traditionally, if you have 4 cores and launch an MPI job with "-np 4", a function foo() will be run on 4 cores (each core running one process) and each core runs foo() with different data.
Now, assume there are 4 MPI processes and each process is running on one core. Each process reaches bar() which is a GPU kernel. When processes 1 offloads bar() on GPU, other processes have to wait.
So, I think using 4 MPI processes in the presence of GPU is tricky. Any thought?
Regards,
Mahmood
a) i already gave you my thoughts
b) perhaps you need to look at some benchmarks and read some papers on
the subject. e.g. the ones describing the GPU package in LAMMPS.
