Three body terms in tersoff/zbl implementation
Dear LAMMPS community,
I have searched online, but could not find the answer to my question. Still, I hope this topic is not redundant with an already existing one.
As I wanted to understand how the coupling between tersoff and ZBL is implemented in the pair tersoff/zbl LAMMPS command, and especially how the three body terms are handled, I read through the pair_tersoff_zbl.cpp file. I was surprised to find no trace of three body terms, namely zeta or b_ij terms as they are called in the pair_tersoff.cpp file.
The three-body parameters lambda_3, powern, powerm, beta, c, d and gamma are read from the potential file but not used.
My understanding is thus that the tersoff/zbl potential only includes two-body repulsive and attractive terms. However, on the pair_tersoff_zbl html page there is nothing indicating that the three body “bond-order” term b_ij is discarded when tersoff is coupled to zbl. I guess there is something I am missing, but I do not understand what.
I would really appreciate some help on this point, thanks in advance !
Best regards
Thomas
If you look at pair_tersoff_zbl.h (the header file, not cpp file) you will see that PairTersoffZBL inherits from PairTersoff (line 27). In other words PairTersoffZBL is a specialisation of PairTersoff, which overrides some functions (see the override keywords?) but inherits everything else, including those terms you couldn’t find in the cpp.
That understanding is incorrect.
You are disregarding that LAMMPS’ code design makes use of C++ classes, inheritance, compositing, and specifically polymorphism. Please see 4.3. Code design — LAMMPS documentation for a minimal introduction and a proper C++ text book for the gory details.
Thanks to both of you for your quick reply !
