Dear All,
I am trying to simulate microbial interactions in a waste water treatment plant in which microbes grow over time. As a start I am trying to model sedimentation of very dilute phase with microbes falling under gravity and use fix viscous to include hydrodynamic interactions.
I was wondering if this could be done using existing capabilities of LAMMPS. I am specifying particles of type sphere with finite diameter and density.
As a initial guess, may be something fix that could do: d(t) = d(t-1) + growthrate(t)*t ? or closest fix i could modify?
I would deeply appreciate any pointers/help in this regard.
Kind regards
Prashant
Fix adapt can be used to time-vary the diameter of particles of type atom_style sphere.
Everything else you described seems do-able with the commands you mentioned.
Thanks steve for the reply,
A follow up question: could I break an atom to 2 if say it exceeds a maximum diameter using some fix or replace atoms ?
Kind regards
Prashant
technically, yes, buy you would have to write that fix. i don't think
that any of the existing fixes can be used for that.
Thanks for the replies Axel.
Another follow up question: If there is a closest fix i could modify for the atom division: i.e. replacing the atom with 2 daughter atoms if say it exceeds a maximum diameter (done using fix adapt)?
I would write the fix myself, i am just looking for a closest starting point.
Thanks again
Kind regards
Prashant
If you’re going to add atoms, you should look at other
fixes that do that, b/c they need to operate at a particular
point in the timestep. See fix deposit or fix pour for examples.
