Timer timeout command in lammps
I have used the timer timeout command in the lammps input as :
timer timeout 94:00:00
However, in the log file of lammps I see:
New timer settings: style=normal mode=nosync timeout=22:00:00.
So, it’s basically 94 hours modulo 24 hours.
The screenshot from the simulation is attached here.
I am using the first update of 23rd June, 2022 stable version of lammps.
Is this supposed to work this way ?
Or am I misunderstanding this.
Thanks.
Yes and no. The parsing of the time has worked correctly, but there is an output format error.
This will be corrected in a future LAMMPS release.
Many Thanks, Axel !
Indeed, I did a mock run to see that the timer works well, and is just an issue with the display.
