Hi Alex,
Thanks for taking the time to write the detailed answer. The point that I
couldn’t quite get is what makes constrained dynamics which is numerically
approximated by SHAKE/RATTLE/LINCS differ from the real rigid body
equations of motion. The fundamental reason you gave suggests that these
are different physical processes. However, in my understanding, they are
mathematically equivalent in the continuous scenario. In other words,
integrating EOM for individual particles plus applying constrains or
directly integrating EOM for the body are two numerically different ways to
approach the same physical trajectory. If this understanding is correct,
starting from the same point in phase space, exact integration of both
schemes should land on the same place after the same time interval, meaning
all DOFs in the system should make the same amount of displacement. Any
discrepancy should be due to numerical instead of physical reasons.
SHAKE and related algorithms work well for "local" rigidity, e.g. keep all
bonds to hydrogens in a (large) molecule at fixed length, or keep small
molecules rigid, as that keeps it relatively easy and efficient to
(iteratively and approximately) solve the system of constraint equations,
especially when running in parallel. so it is only an approximation to a
rigid body integrator.
with SHAKE (or SHAKE+RATTLE) you first do an unconstrained position (and
velocity) update and then apply the constraints, i.e. modify the
position/velocity update, so that the constrains are satisfied to the
requested degree. that basically makes the time scale for updates, the time
scale of non-bonded position updates. with typical MD systems, you have
quite soft potentials, which can tolerate larger time steps without too
much of an error. however, it is crucial, that the constraint equations
converge well, which requires them to have near diagonal coefficient
matrix. also, please keep in mind that you approximate a system non-linear
equations with linear equations.
in rigid body integrators, you do not do position updates for individual
atoms, but separate the center of mass and rotation updates, so now the
time scales for each of those matter.
As to the integration algorithm with rigid and body, what I found in the
code is that fix nve/body uses a Richardson iteration to update the
quaternion after the angular momentum is updated by the torque. According
to the documentation, fix rigid/nve uses Miller’s nosquish algorithm for
integrating quaternion dynamics. That algorithm separates the rotation into
two parts, one caused by torque and one free of torque. The latter part is
integrated with a finer discretization within each timestep. I haven’t
fully grasped the details of the algorithm but am wondering if that is
sufficient for a significant boost of timestep. You’re absolutely right
that I should simply run a test. I haven’t checked any fix with thermostat
but NVE is sufficient for us for now.
yeah, some kind of multi-timestepping might be helpful. not sure, though,
how far you can get with typical molecular systems assuming the torque
doesn't change (much). it may be worth considering/testing distance based
multi-timestepping via run-style respa. depending on your system, it may be
quite reasonable to assume that the interactions affecting torque are short
ranged and thus only a subset of interactions will need to be recomputed at
every time step.
keep in mind, that the computational efficiency of your simulations is the
product of how long a timestep you can afford and how costly the
computation of interactions is. there are some examples in the literature,
that may not be intuitive, e.g. it may be computationally more efficient to
represent a complex "shaped" object by a superposition of - extremely fast
to compute - point particles rather than having to compute relative
orientations and surface shape dependent interactions.
