Dear lammps-users,
I use TIP4P model of water in my system. For pair style, I’m setting the following;
pair_style hybrid buck/coul/long 8.5 lj/cut/tip4p/long 3 4 2 4 0.1546 8.5
In the doc page for lj/cut/tip4p/long it is written: “style lj/cut/tip4p/long is for use with a long-range Coulombic solver (Ewald or PPPM).”
Is it correct to infer that if I’m using lj/cut/tip4p/long, then “kspace_style ewald 1e-6” will take into account the charge distance from O site in TIP4P?
If so, then why is there a special “pppm/tip4p” to account for long range forces?
I’m using 11Aug17 version of lammps.
Thank you and best regards,
Ali
Dear lammps-users,
I use TIP4P model of water in my system. For pair style, I'm setting the
following;
In the doc page for lj/cut/tip4p/long it is written: "style
lj/cut/tip4p/long is for use with a long-range Coulombic solver (*Ewald*
or PPPM)."
Is it correct to infer that if I'm using lj/cut/tip4p/long, then
"kspace_style ewald 1e-6" will take into account the charge distance from O
site in TIP4P?
that is not correct.
If so, then why is there a special "pppm/tip4p" to account for long range
forces?
it is there because you must have a modified long-range solver to account
to the charge at a different location than the oxygen location without
explicitly defining its position.
Dear axel,
Thanks for the response. One more thing:
Does that mean that currently it’s not possible to use ewald summation with TIP4P because we don’t have “ewald/tip4p” option?
Ali
Dear axel,
Does that mean that currently it's not possible to use ewald summation
with TIP4P because we don't have "ewald/tip4p" option?
pppm is equivalent to ewald and usually (much) faster.
you can also model TIP4P without any of the “tip4p” styles, by defining it through 4 explicit sites and using fix rigid or fix rigid/small instead of fix nve + fix shake to do time integration for the TIP4P water molecules. please search the mailing list archives, this topic has been discussed several times.
It is not currently possible and should error out. I agree the docs are a bit misleading because they mention Ewald in the doc page for lj/cut/tip4p/long.
Stan
