this is a visualization problem and due to the fact, that you are
visualizing the system without using the image flag information.
below is the first chunk of my log file. i am also attaching a
snapshot from a VMD visualization from loading the topology first and
then a dump with image flags enabled.
in VMD then i ran the commands:
pbc box
pbc wrap -compound fragment
and created the image.
LAMMPS (4 Jan 2019)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread.
(src/comm.cpp:87)
units metal # eV, Ang, ps
variable kcal_mol equal 43.36e-3 # eV
atom_style full
newton on
bond_style harmonic
angle_style harmonic
dihedral_style none
improper_style none
read_data water.dump
orthogonal box = (0.02645 0.02645 0.02641) to (35.5328 35.5328 35.4736)
reading atoms ...
4500 atoms
scanning bonds ...
2 = max bonds/atom
scanning angles ...
1 = max angles/atom
reading bonds ...
3000 bonds
reading angles ...
1500 angles
2 = max # of 1-2 neighbors
1 = max # of 1-3 neighbors
1 = max # of 1-4 neighbors
2 = max # of special neighbors
velocity all set 0.0 0.0 0.0
group water type 1 2
4500 atoms in group water
# TIP4P/Ice
bond_coeff 1 44.0 0.9572 # 1000 kcal/mol ~= 44 eV
angle_coeff 1 44.0 104.52
set type 1 charge -1.1794
1500 settings made for charge
set type 2 charge 0.5897
3000 settings made for charge
thermo_style custom step temp epair etotal ndanger
thermo 10
neighbor 4.0 bin
timestep 1e-3 # ps
##### MINIMIZING BOND LENGTH AND ANGLE TO EQUILIBRIUM ONES ######
pair_style lj/cut 10.0
pair_coeff * * 0.00000 0.0000
min_style cg
minimize 1e-15 1e-15 100000 10000000
Neighbor list info ...
update every 1 steps, delay 0 steps, check yes
master list distance cutoff = 14
ghost atom cutoff = 14
binsize = 7, bins = 6 6 6
1 neighbor lists, perpetual/occasional/extra = 1 0 0
(1) pair lj/cut, perpetual
attributes: half, newton on
pair build: half/bin/newton
stencil: half/bin/3d/newton
bin: standard
Per MPI rank memory allocation (min/avg/max) = 25.68 | 25.68 | 25.68 Mbytes
Step Temp E_pair TotEng Ndanger
0 0 0 734.12446 0
10 0 0 0.11575358 0
20 0 0 0.11574452 0
30 0 0 0.00032672595 0
40 0 0 9.9404306e-15 0
45 0 0 1.6733136e-21 0
Loop time of 12.5648 on 1 procs for 45 steps with 4500 atoms
98.5% CPU use with 1 MPI tasks x 1 OpenMP threads
Minimization stats:
Stopping criterion = linesearch alpha is zero
Energy initial, next-to-last, final =
734.124460728 1.67331364543e-21 1.67331364543e-21
Force two-norm initial, final = 559.975 9.48162e-10
Force max component initial, final = 8.47879 3.21812e-11
Final line search alpha, max atom move = 0.5 1.60906e-11
Iterations, force evaluations = 45 186
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
