Dear all:
I know it was asked in an earlier post about TIP5P, but I was curious if anyone was currently working on trying to implement a five-point model in LAMMPS right now. One of my students is interested in working with TIP5P, so it would be good to know if anybody is currently developing such a model, or if there is sufficient interest to be worth doing it ourselves.
—AEI
Dear all:
you can easily set up TIP5P using fix rigid/small. either disable the
test for per type mass == 0 or use something small like 1.0e-10.
only downside is the rather short time step required to have stable
time integration with rigid bodies.
I guess the big question here is how small does that time step need to be? With TIPxP styles, we can use SHAKE to get away with a 2 fs time step. I’d rather not have to do 20 or 30 time steps to replace that; I doubt that would be very efficient in the long run.
—AEI
> Dear all:
> in
> TIP5P, so
> model, or
With TIPxP styles, we can use SHAKE to get away with a 2 fs time step. I'd
how small would depend on your system and the kind of dynamics
happening. i would expect you have to use about 0.5fs. on a well
equilibrated bulk system you may get away with a larger time step.
that is still a significant cost compared with 2fs, but not as drastic
as you suspect it could be.
i view efficiency from the perspective of time to solution. these
days, it is often easier to get more CPU time, than to get your hands
on a suitably motivated student or postdoc that can program well
enough, not to count the time it will take to implement and test such
a new pair style compared to being able to start a production run
right away. while you can in principle follow the same approach as for
TIP4P, things get a little bit more complex for TIP5P, as you have to
not just displace one position, but have to do this twice, and if you
want to use long-range electrostatics, you need a matching kspace
style as well.
Hi Ahmed - I agree with the discussion points on this. If someone
created a pair_tip5p style that was specific to the TIP5P model
(allowed long timesteps, etc), it would be a nice addition to LAMMPS.
