Dear Andrew
I tested the recommended scripts for the binary mixture of TIP5P/TIP4P/TIP3P water with OPLSAA ethanol one by one and the result are attached in this eamil. For TIP5P water+OPLSAA ethanol, these three methods listed below can converge to the right results. But systems performed by some other methods seems to expand continually which is odd and i still can not figure it out.
Method 4
fix fxH2O H2O rigid/nph/small molecule iso 1 1 1000 dilate all
fix fxEthanol ethanol nve
fix fxLanvegin all langevin 298 298 100.0 48279
Correct
Method 5
fix fxH2O H2O rigid/npt/small molecule temp 298 298 100 iso 1 1 1000 dilate all
Correct
Method 8
Correct
Here is the detailed explanation for hybrid simulation with rigid and non-rigid particles i found in lammps mannual:
If you with to perform NPT or NPH dynamics (barostatting), you cannot use both fix npt and the NPT or NPH rigid styles. This is because there can only be one fix which monitors the global pressure and changes the simulation box dimensions. So you have 3 choices:
Use one of the 4 NPT or NPH styles for the rigid bodies. Use the dilate all option so that it will dilate the positions of the non-rigid particles as well. Use fix nvt (or any other thermostat) for the non-rigid particles.
Use fix npt for the group of non-rigid particles. Use the dilate all option so that it will dilate the center-of-mass positions of the rigid bodies as well. Use one of the 4 NVE or 2 NVT rigid styles for the rigid bodies.
Use fix press/berendsen to compute the pressure and change the box dimensions. Use one of the 4 NVE or 2 NVT rigid styles for the rigid bodies. Use fix nvt (or any other thermostat) for the non-rigid particles.
In all case, the rigid bodies and non-rigid particles both contribute to the global pressure and the box is scaled the same by any of the barostatting fixes.
Best regards
Yalishanda
------------------ Original ------------------
TIP3P+OPLSAA.txt (872 Bytes)
TIP4P+OPLSAA.txt (1.04 KB)
TIP5P+OPLSAA0730.txt (1.17 KB)
