I have some questions, more technical ones, related to ATAT and your paper here: https://dx.doi.org/10.1103/PhysRevB.86.134117
This is my first encounter with cluster expansion and ATAT and Cluster Expansion. I hope that you can help me with some basic techniques on performing cluster expansion calculations with ATAT code. I tried to read the manual as well as scan the ATAT forum, but still could not really solve my own problem.
First of all, I use Quantum Espresso.
So, my system is an oxide with vacancies (SrFeO3-x). As the vacancy concentrations increase, the phase of the structures changes from cubic, to tetrahedra, to orthorhombic, and finally to brownmillerite, according to the experiments. My questions are:
- Should I do DFT-CE calculations with volume and shape relaxations? After relaxations, should I do static calculations to get the energy? I did relaxed volume and shape, but the results says true ground-states differ from the predicted ground-states. Also, some of the predicted ground-states crosses the convex-hull of the calculated ground-states. I read in this forum that I should constraint maps by defining a smaller window of concentrations with -c0 and -c1. But when I did this, maps often stop generating new structures (stuck at `Finding best structures’ but never generating any new structures). I suspect that the concentration window is to small, though I am not really sure about it.
- If I have to fix the volume and shape, then how do I compensate the volume and shape relaxations in contributing to the total energy? In https://dx.doi.org/10.1103/PhysRevB.86.134117, it was mentioned that the volume relaxation was accounted by multiple constant volume calculations for each structure. So, how exactly can we do this with ATAT?
- If I have to calculate for each phase, should I make different directories for each phase? How to combine them in the end so that I can get the ECI which covers all the changes? how to define the concentration range (-c0 and -c1) in this case?
- When I got this message: `true ground-states differ from the predicted ground-states’ but my cv-score is low enough, should I ignore the message? Can I still use the ECI coming from this calculations?
- Sometimes during DFT calculations on the generated structures by maps, it fails to reach convergence. In quantum espresso, the calculations will be terminated immediately and took the latest recorded total energy. What should I do about it? Should I run DFT to this specific directory and write down the converged total energy to `energy’ files by hand?
Thank you very much before.
Musa
