I am trying to do a simple test to compare the effects of “Nose-Hoover” thermostats with “DPD” thermostats on my model. In my model, I am simulating water transport through CNT.
To this aim, I applied “fix nvt” to perform time integration on Nose-Hoover thermostats. I also used “pair_style lj/cut/coul/long 10.0 10.0” in conjunction with that to do force field interaction.
To apply DPD thermostats I am not sure how can I use it correctly in my script?
Because, by referring to mailing list archive I found that the experts at this link (http://lammps.sandia.gov/threads/msg38906.html) commented that we can not use “fix nvt” with “pair style dpd” at a same time. But, when referring to the dpd doc page at (http://lammps.sandia.gov/doc/pair_dpd.html) it has mentioned that " This pair-wise thermostat can be used in conjunction with any pair style, and in leiu of per-particle thermostats like fix langevin or ensemble thermostats like Nose Hoover as implemented by fix nvt".
Regarding to my poor MD knowledge, if we want to use “DPD” thermostats with out “fix nvt” how would be able to do time integration?
I also did a small test by applying “dpd” with no “fix nvt” to see the thermodynamics quantities . But, the values are not changed. Please take a look at below
I am trying to do a simple test to compare the effects of "Nose-Hoover"
thermostats with "DPD" thermostats on my model. In my model, I am simulating
To this aim, I applied "fix nvt" to perform time integration on Nose-Hoover
thermostats. I also used "pair_style lj/cut/coul/long 10.0 10.0" in
script?
can not use "fix nvt" with "pair style dpd" at a same time. But, when
Regarding to my poor MD knowledge, if we want to use "DPD" thermostats with
out "fix nvt" how would be able to do time integration?
your problem is not exactly due to poor MD skills, but rather due to
poor reading skills. if you read the sentence directly before and the
one directly after the text you quoted, you have your answer: this
segment refers to pair style dpd/tstat and not dpd and you need to use
it in combination with the hybrid/overlay pair style.
I also did a small test by applying "dpd" with no "fix nvt" to see the
look at below
I would be greatly appreciated if anybody guides me how I can apply dpd
thermostats properly.
sorry, but - as has been repeatedly pointed out - this mailing list is
not a classroom. find yourself a proper tutor. given your difficulties
to teach yourself from the available tutorial and documentation
material, there really is no alternative and no hope to get any
meaningful simulations done. without the personal tutoring and
feedback from somebody with MD experience, you are likely to make many
mistakes and errors, often without even noticing.
Once you turn-off fix not and use dpd/tstat, you need
to use fix nve to integrate the atoms. W/out that
the atoms won’t move and that’s why the temperature
isn’t changing.
