Hello all
I would to calculate the bond order parameter using the nearest same type of atom. That is, say in a system of water and NaCl ions, I want to use only the nearest neighbors of NaCl ions in my orientorder/atom calculations.
Hello all
Available options on how to use the orientorder/atom command are listed in the documentation. If that is not sufficient for your needs, you will have to modify the source code.
ok got it
