I am trying to build a cluster expansion for a Li–Ti–Mn–O system using icet. In my generated structures, I enforce fixed oxidation states: Li+, Mn3+, Ti4+, and O2−. Because of charge neutrality and the fixed rocksalt sublattice ratio, once the Mn concentration is chosen, the Li and Ti concentrations are also determined.
The feature matrix has a very large condition number. I suspect that this comes from linear dependencies induced by the charge-neutrality constraint. I identified a dependent parameter and first tried to resolve it using merge_orbits, but this did not work. My guess is that the dependency is not between different orbits, but between different parameters within the same orbit.
As a test, I constructed a reduced feature matrix by removing one column corresponding to a linearly dependent CE parameter. The condition number was initially around 500 and decreased to around 100 after annealing.
Is this a reasonable approach? More specifically, is it acceptable to remove a charge-neutrality-induced dependent parameter and perform selection/fitting using the reduced feature matrix?
Thank you.
