I posted this question to the VMD mailing list a week ago but got no
answer, so I'm giving it a try here...
I am trying to build a system consisting of a bubble in an aqueous
electrolyte. I generate a pdb file using packmol, and I then convert
it to a lammps data file using the VMD Topotool plugin:
topo retypebonds
topo guessangles
topo writelammpsdata data0
For small bubbles (and small simulation boxes) everything works fine,
but above a certain system size vmd crashes (my last try was with a
little bit more than 500'000 atoms, but it crashed even for smaller
systems). Could it be related to the "small amount" of memory on my
laptop (8 GB)? How could I solve this issue?
Laurent
sorry, but it went by me due to running the LAMMPS workshop here in trieste.
topo retypebonds
topo guessangles
not sure. is this on linux or windows and 32-bit or 64-bit?
i recall fixing some size related issues in the past. if there is a
simple way to reproduce the crash, i can try running on a machine with
much more RAM.
unless there are some constraints that you didn't tell us, i would
just create a reasonably sized equilibrated box of the electrolyte and
then use the replicate and delete_atoms commands in combination with a
spherical region to prepare that kind of system. then define a larger
spherical region to get a group of molecules and do a
minimization/quench/equilibration of this layer and then simulate the
entire system.
