thanks for your answer.
sorry for my trivial question.
yes. but i don’t know how to do it in lammps?
which command should i use?
Best
yes. but i don't know how to do it in lammps?
yet, that is the wrong approach. before looking into what command exactly
would be needed in LAMMPS, you need to understand, how adding a force
through using fix addforce will change the force between two groups.
start with a piece of paper and a pencil. make some simplified model and
start thinking!
depending on your system and your specific fix addforce command, you may be
able to fully pre-compute the impact of fix addforce. you may even find
that it has no impact at all. like i said previously, this all comes down
to a little bit of vector algebra.
