turning off angles and dihedrals
Hi all,
I'm running a simulation with pairwise, bonded, angle and dihedral interactions. ``I need to use the fix bond/break command to remove bonds in the system, ``but I have learned that this command does not affect the angle interactions.
1-I was wondering if there is a method using which I can ``turn off the angle and dihedral interactions between atoms that include the broken ``bond, but only when the bond breaks.
2-Regardless of the fix bond/break command is there any way to turn off the angle and dihedrals in a specific region or for specific group of atoms?
Thank you in advance,
Shahin Shadlou
Comments below.
Hi all,
interactions. I need to use the fix bond/break command to remove bonds in
the system, but I have learned that this command does not affect the angle
interactions.
1-I was wondering if there is a method using which I can turn off the angle
and dihedral interactions between atoms that include the broken bond, but
no - that logic would have to be added to the fix bond/break command.
The delete_bonds command can do this.
