it looks as if there a small mix up in the correction description:
MP Gas Correction
Correct anion energies to obtain the right formation energies. Note that this depends on calculations being run within the same input set.
MP Anion Correction
Correct gas energies to obtain the right formation energies. Note that this depends on calculations being run within the same input set.
