I am testing several workflows and have noticed for each workflow submission I receive the warning,
UserWarning: Could not load default_magmoms.yaml, falling back to VASPIncarBase.yaml
warnings.warn("Could not load default_magmoms.yaml, "
And as a result the INCAR for each respective run sets the MAGMOM tag to zero. I believe this may be impacting the accuracy of my calculations. Please advise on how to correct this.
Also note that the magnetic workflow has a keyword argument (default_magmoms ) to supply your own magmoms dictionary, so you can do that too, e.g. default_magmoms={"Fe": 5}. If you supply the magmoms yourself in this manner, you do not need the default_magmoms.yaml file.
Hope this helps, let me know if there are other questions!
