Dear lammps users:
I am attaching (and copying at the end) a simple script that generates a water box (using a H2O molecule file also attached).
Running lammps from 1Jul16 I found segmentation fault after the “uncompute” of last line.
Running the last version to date (9Jan17) and the last stable version (17Nov16) I obtained a weird error message: “ERROR: Could not find fix ID to delete (…/modify.cpp:906)” … I am trying to uncompute the previous compute, but the error is about a fix ID. I don’t understand.
This is a simplified version of my original input script. I am interested to calculate msd from a chunk of atoms and redefine the chunks every 10 or 50 ps (include compute chunk/atom and uncompute in a loop)
Here is the input file:
atom_style full
lattice sc 3.104 ### density of water 1 g/cm3
region bulto block -5 5 -5 5 -5 5
create_box 2 bulto bond/types 1 angle/types 1 extra/bond/per/atom 2 extra/angle/per/atom 2 extra/special/per/atom 2
bond_style harmonic
angle_style harmonic
molecule 1 H2O_mol.txt ## Read H2O molecule
create_atoms 0 region bulto mol 1 27236
bond_coeff 1 24.029 1
angle_coeff 1 1.985 109.47
mass 1 15.9994
mass 2 1.0008
group O type 1
group H type 2
pair_style lj/cut/coul/long 9
pair_modify mix arithmetic ##sigma es promedio aritmetico, epsilon promedio geometrico
pair_coeff 1 1 0.00673878 3.16554132
pair_coeff 2 2 0 0
kspace_style pppm 1.0e-4
thermo 10
thermo_style custom step temp ke pe etotal press pxx pyy pzz vol lx ly lz
timestep 0.001 # 1 fs
run_style respa 2 2 pair 1 kspace 2
special_bonds lj/coul 0.0 0.0 1.0
fix nvt all nvt temp 298 298 0.1
compute 10 O chunk/atom bin/cylinder z lower 50.0 0.0 0.0 5 14 3 nchunk once units box
run 100
uncompute 10
The H2O_mol.txt is:
Molecule H2O
3 atoms
2 bonds
1 angles
Coords
1 0 0 0
2 0.8164904 0.00000 0.5773590
3 -0.8164904 0.00000 0.5773590
Types
1 1
2 2
3 2
Charges
1 -0.82
2 0.41
3 0.41
Bonds
1 1 1 2
2 1 1 3
Angles
1 1 2 1 3
H2O_mol.txt (214 Bytes)
in.water_box (1.17 KB)
