The
make
succeeded in producing the libkim.a
but failed on the TESTs section
g++44 -O3 -I/usr/local/apps/openkim/gcc44/openkim-api-v1.0.1/
KIM_API/ -Wno-write-strings -D KIM_DIR_MODELS=\"/usr/local/apps/
openkim/gcc44/openkim-api-v1.0.1/MODELs/\" -D KIM_DIR_API=\"/usr/local/
apps/openkim/gcc44/openkim-api-v1.0.1/KIM_API/\" -D KIM_DIR_TESTS=\"/
usr/local/apps/openkim/gcc44/openkim-api-v1.0.1/TESTs/\" -D
KIM_DIR_MODEL_DRIVERS=\"/usr/local/apps/openkim/gcc44/openkim-api-
v1.0.1/MODEL_DRIVERs/\" -D SYSTEM64 -lgfortran
ex_test_Al_FCCcohesive_MI_OPBC.o -L/usr/local/apps/openkim/gcc44/
openkim-api-v1.0.1/KIM_API/ -lkim -o ex_test_Al_FCCcohesive_MI_OPBC
/usr/lib/gcc/x86_64-redhat-linux6E/4.4.0/../../../../lib64/crt1.o: In
function `_start':
(.text+0x20): undefined reference to `main'
so I went ahead with my lammps install -- but would have been more
comfortable if had had some indication that tests were successful
Regards,
Gary Howell
Thanks for posting your question to the list.
I see that you are using the 4.4 version of the gnu compiler suite.
We have found that, with this version, it is best to link executable programs using the gfortran compiler as opposed to using g++.
So, you should change lines 57-60 of KIM_API/GNU_compiler_settings.mk from
CPPLIBFLAG = -lgfortran #if GNU version 4.5 and up. tested on suse
LINKCOMPILER = \(CPPCOMPILER\) \#if GNU version 4\.5 and up\. tested on suse
\#CPPLIBFLAG = \-lstdc\+\+ \#if GNU version 4\.4\.1\. tested on suse
\#LINKCOMPILER = (FORTRANCOMPILER) #if GNU version 4.4.1. tested on suse
to
#CPPLIBFLAG = -lgfortran #if GNU version 4.5 and up. tested on suse
#LINKCOMPILER = \(CPPCOMPILER\) \#if GNU version 4\.5 and up\. tested on suse
Hope that works. Let us know.
Cheers,
Ryan Elliott
