Uniaxial tensile of graphene
I’m trying to apply uniaxial tensile loading on graphene sheet with the latest Lammps version. The uniaxial deformation is applied via ‘‘velocity’’ command. But the strange problem is that, though the script runs well, there is no axial deformation at all (the box size does not change). I have checked the script many times but could not find out where the bug is. Anyone could help me about this? My script is as follows:
boundary p s s
atom_style atomic
neighbor 2.0 nsq
neigh_modify every 10 check yes
read_data graphene.dat
potentials
pair_style airebo 2.0
pair_coeff * * CH.airebo C
mass 1 12.0
groups
region Ledge block INF 6.0 INF INF INF INF units box
region Redge block 332.0 INF INF INF INF INF units box
group left region Ledge
group right region Redge
group boundary union left right
group mobile subtract all boundary
initial velocities
velocity all create 300.0 5201314 dist gaussian
velocity all zero linear
velocity all zero angular
compute myTemp mobile temp
thermo 500
thermo_style custom step c_myTemp etotal lx ly lz pxx pyy pzz
dump 1 all atom 500 equil.lammpstrj
energy equilibration
min_style cg
minimize 1.0e-15 1.0e-10 10000 10000
velocity boundary set 0.0 0.0 0.0
fix 1 boundary setforce NULL NULL 0.0
fix 3 mobile nvt temp 300.0 300.0 0.1
fix_modify 3 temp myTemp
reset_timestep 0
run 10000
unfix 3
unfix 1
undump 1
tensile deformation
reset_timestep 0
fix 1 boundary setforce 0.0 0.0 0.0
velocity left set -0.17 0.0 0.0
velocity right set 0.17 0.0 0.0
dump 1 all atom 1000 deform.lammpstrj
variable stress equal -pxx0.1 #MPa
variable strain equal step
0.000001 #
fix def_print all print 1000 “{strain} {stress}” file curve.dat screen no
run 300000
Thank you so much!
WL
graphene.dat (479 KB)
If you are not integrating your boundary atoms they
won’t move, no matter what their velocity or
forces on them.
