When I am subjecting the simulation box to tension in x-direction, it soon starts to expand in Y and Z directions too. Is this because of a high strain rate? Also the stress in X-direction is negative from 0.05 to 0.09 strain.
My code is attached below.
The tension application code:
variable a loop 2
label loop
fix 27 all npt temp 300 300 1 iso 0 0 1 drag 1
thermo 1000
thermo_style custom step temp press ke pe etotal vol density
run 90000
unfix 27
fix 28 all nve
thermo 1000
run 50000
unfix 28
fix 29 all npt temp 300 300 1 y 0 0 1 z 0 0 1 drag 1
variable srate equal 1e10
variable srate1 equal “v_srate/1.0e12”
fix 30 all deform 1 x erate ${srate1} units box remap x
Output strain and stress info to file
# for units metal, pressure is in [bars] = 100 [kPa] = 1/10000 [GPa]
# p2, p3, p4 are in MPa
variable strain equal “(lx - v_L0)/v_L0”
variable strain_y equal “(ly - v_Ly0)/v_Ly0”
variable strain_z equal “(lz - v_Lz0)/v_Lz0”
