I have a quiet annoying problem with a couple of lpad-commands after I ran most of the fw_tutorials (I don’t know exactly after which it started happening).
So in some of the tutorials you are submitting a test fireworks with AdditionTask and now after quite a lot of lpad-commands these lines appear in the terminal output:
2019-04-26 12:51:28,114 INFO Performing db tune-up
2019-04-26 12:51:28,145 INFO LaunchPad was RESET.
2019-04-26 12:51:28,146 INFO Added a workflow. id_map: {-1: 1}
2019-04-26 12:51:28,146 INFO Launching Rocket
2019-04-26 12:51:28,352 INFO RUNNING fw_id: 1 in directory: /home/huelsberg/local/hilde/examples/phono3py/fireworks
2019-04-26 12:51:28,356 INFO Task started: Addition Task.
The sum of [1, 2] is: 3
2019-04-26 12:51:28,356 INFO Task completed: Addition Task
2019-04-26 12:51:28,363 INFO Rocket finished
It also writes a FW.json file in the current launch directory, which I attached. However, the workflow does NOT appear in the database, so I cannot find it via lpad get_fws/get_wflows or in the webgui. The id_map is always {-1: 1}, the run_directory changes dynamically though.
Here is a list of commands where this problem appears (not complete):
lpad get_fws (+ options)
lpad add bla.yaml
rlaunch singleshot (-f <fw_id>)
lpad rerun_fws (-i <fw_id>)
With these commands, it does not appear (also not complete):
lpad get_wflows
lpad detect_lostruns
lpad delete_wflows (-i <fw_id>)
-h
I already tried reinstalling, but not recloning the repository. I don’t have this problem on another machine (using the same database), so it should be a problem on my local machine.
Any help is appreciated.
Marcel
FW.json (1.1 KB)
