Based on which unit (real, metal, …) does msi2lmp work? That is, which unit should we use in the input file when we utilize a data file produced by msi2lmp?
This is important esp. for distance, energy, force, and time parameters. Thank you.
Based on which unit (real, metal, ...) does msi2lmp work? That is, which
by msi2lmp?
that depends on the units used in the corresponding .frc file. for the
files bundled with msi2lmp it would be real units.
So, as a suggestion, a note can be added to the README file in the msi2lmp folder, indicating that the unit is real…
Bests
Mah
That would be incorrect. It doesn’t have to be. Didn’t you read what I wrote??
