Dear All,
When I use the SLLOD equations of motion to evaluate the viscosity of ionic liquids, I get values that are about a hundred times higher than experimental values and values obtained from equilibrium Green-Kubo relations using Gromacs. Otherwise the qualitative functional dependence of the viscosity on the shear rate seems to be reasonable. Therefore, I wonder whether I use the wrong units for the pressure or the velocity gradient. I use the option "units real" where the pressure unit is atmospheres and the time unit is femtoseconds, so that the unit of the velocity gradient ought to be 1/femtoseconds. The results would be much more reasonable if the pressure unit was kPa.
Best Regards,
Sten Sarman
