I downloaded the latest stable version of lammps (17Nov2016) and was checking out the USER-SMD package. I did a make package-USER-SMD, went to the lib/smd directory and created the link to the required Eigen libraries. I compiled lammps with a “make g++” command and go an executable lmp_g++.
I copied this into the “examples/USER/smd/aluminum_strip_pull” directory and did a run as follows:
mpirun -np 2 ./lmp_g++ < aluminum_strip_pull.lmp
I get the following error:
ERROR: Unknown compute style (…/modify.cpp:997)
This was unexpected since I have compiled lammps with the package USER-SMD. It did not give me an error with the “pair_style smd/tlsph” command which precedes the compute “dt_atom all smd/tlsph_dt” command.
What could I be doing wrong?
Thank you for your time.
Best Regards
Manoj
