Unphysical charges when using QEQ/point with multiple run statements
Hello Lammps users,
I am using QEQ to simulate a system of electrolytes in solutions, and would like to perform annealing. The problem is that when I try to use multiple run statements in the same input file, I will get unphysical charges, often leading to coulomb catastrophy. When I instead write to a data or restart file and then read that to start a second simulation, I am not running into the same error. I have tried both the 17Nov16 and 11Aug17 versions and this occurs with both. This is a sample of what my input file looks like
units real
atom_style full
pair_style lj/cut/coul/long 12
kspace_style ewald 0.0001
pair_modify tail yes
pair_modify mix arithmetic
special_bonds amber
bond_style harmonic
angle_style harmonic
dihedral_style charmm
improper_style cvff
read_data mol.data
group ions type 1 2 3
group Li type 1
group Cl type 2
group O type 3
compute chargeLi Li property/atom q
compute qLi Li reduce ave c_chargeLi
compute chargeCl Cl property/atom q
compute qCl Cl reduce ave c_chargeCl
compute chargeO O property/atom q
compute qO O reduce ave c_chargeO
neighbor 2.0 bin
neigh_modify delay 0 every 1 check yes page 1000000 one 20000
timestep 1.0
velocity all create {mytemp} 314159265 units box velocity all zero linear units box dump DUMP all custom 5000 {NAME}.lammpstrj id type x y z vx vy vz mol
thermo_style custom step cpu cpuremain c_qLi c_qCl c_qO vol temp press ke pe etotal enthalpy evdwl ecoul epair ebond eangle edihed eimp emol elong etail lx ly lz xy xz yz density
thermo 1000
minimize 1e-4 1e-6 10000 10000
fix QEQ ions qeq/point 1 12 1.0e-6 1000 param.qeq
fix NPT all npt temp 300 300 100.0 iso 1.0 1.0 100.0
run 1000000
unfix QEQ
run 1000000
Is there an error in my input file, or is this a bug in LAMMPS?
Thanks for your help,
Michael Humbert
Fix qeq/variant does not write resulting equilibrium charges to restart files. In your write data command are you explicitly writing equilibrium charges?
Hi Ray,
I do not explicitly tell it to, but both my restart and data files are saving the equilibrium charges
Michael Humbert
michael,
please have a look at fix store/state. this may offer an opportunity to capture a copy of the equilibrated charges at each time steps, and then use it in combination with the “set” command to re-initialize your charges at the before issuing the next run command from within the same input script.
Hi all,
I still had this issue despite using the set command. I was able to find a solution though. If I use run with pre=no for the second run statement, the charges seem to be stable.
Michael Humbert
