Dear lamms user
I installed LAMMPS distribution from the following way:
http://lammps.sandia.gov/threads/msg51799.html
I decided to use with cuda package. My graphic card is eligible. The CUDA toolkit have installed and it’s in the correct path (usr/local/cuda).
As mentioned in LAMMPS Manual I tried both steps but faced with following error. I will appreciate to help me.
1st way:
python Make.py -p cuda -cuda mode=single arch=20 -o cuda -a lib-cuda file mpi
Error:
mpicxx -restrict -c tmpauto.cpp
g++: error: unrecognized command line option ‘-restrict’
mpicxx -xHost -c tmpauto.cpp
g++: error: language Host not recognized
mpicxx -fno-alias -c tmpauto.cpp
g++: error: unrecognized command line option ‘-fno-alias’
mpicxx -ansi-alias -c tmpauto.cpp
g++: error: unrecognized command line option ‘-ansi-alias’
mpicxx -override-limits -c tmpauto.cpp
compile produced no output
Created src/MAKE/MINE/Makefile.auto
Action exe …
make[1]: Entering directory /home/reza/MD/lammps-7Dec15/src/Obj_auto' Makefile.package.settings:5: ../../lib/gpu/Makefile.lammps: No such file or directory make[1]: *** No rule to make target
…/…/lib/gpu/Makefile.lammps’. Stop.
make[1]: Leaving directory `/home/reza/MD/lammps-7Dec15/src/Obj_auto’
make: *** [auto] Error 2
ERROR: Unsuccessful “make auto”
2nd way:
…/lib/cuda$ make OPTIONS
make: *** No rule to make target `OPTIONS’. Stop.
…/lib/cuda$ make
/usr/local/cuda/bin/nvcc -lib atom_vec_cuda_cu.o comm_cuda_cu.o compute_temp_cuda_cu.o compute_temp_partial_cuda_cu.o cuda_data_cu.o cuda_cu.o cuda_pair_cu.o cuda_wrapper_cu.o domain_cu.o fft3d_cuda_cu.o fix_addforce_cuda_cu.o fix_aveforce_cuda_cu.o fix_enforce2d_cuda_cu.o fix_freeze_cuda_cu.o fix_gravity_cuda_cu.o fix_nh_cuda_cu.o fix_nve_cuda_cu.o fix_set_force_cuda_cu.o fix_shake_cuda_cu.o fix_temp_berendsen_cuda_cu.o fix_temp_rescale_cuda_cu.o fix_temp_rescale_limit_cuda_cu.o fix_viscous_cuda_cu.o neighbor_cu.o pppm_cuda_cu.o -I/usr/local/cuda/include -DUNIX -DFFT_CUFFT -DCUDA_PRECISION=1 -DCUDA_ARCH=20 -L/usr/local/cuda/lib -L/usr/local/cuda/lib64 -lcufft -o liblammpscuda.a
…/src$ make ubuntu
make[1]: Entering directory /home/reza/MD/lammps-7Dec15/src/Obj_ubuntu' Makefile.package.settings:5: ../../lib/gpu/Makefile.lammps: No such file or directory make[1]: *** No rule to make target
make[1]: Leaving directory `/home/reza/MD/lammps-7Dec15/src/Obj_ubuntu’
make: *** [ubuntu] Error 2
Regards
Reza
