Comments below.
Dear All,
I have two questions:
1. Is it possible to use the user-defined many-body potential in LAMPP? I
understand that anything could be done by laborious source code
modification but I mean if there is any standard way of doing it.
What is a user-defined MB potential? There are several in LAMMPS.
2. I found from www pages that LAMPP can be used in conjunction with
GROMACS. Does this mean LAMPP force-fields can be used in GROMACS, in
question, I'm interested in EAM?
It means that LAMMPS has an implementation of the standard GROMACS
pair style, called pair_style gromacs. See the doc page for it.
Dear All,
no. programming the many-body potential is the standard way.
however, lammps is can be singled out as the MD code
where it is the most easy to add your own potential.
no. you are mistaken. lammps provides a potential functional form
that implements the switching function for lennard-jones and coulomb
that is used in gromacs. nothing else.
if you want EAM in gromacs, you should talk to the gromacs people.
