User defined parameter
Dear All,
I would like to play around with a new interacting potential between particle i and j. The potential strength “alpha” is used in the pair_style dpd.
So far I declare in the pair_dpd.cpp this variable:
double alpha=0.1;
and whenever I change this value, I have to recompile LAMMPS.
My question if there is a way to define alpha as a parameter in the input file, and called by LAMMPS such that I can change this value without recompile LAMMPS?
I have tried to with:
variable alpha equal 0.1
But don’t know how to call by pair_dpd.cpp
Thank you very much.
The LAMMPS manual has a detailed discussion of implementing a pair style from scratch and that includes how to set either global or per pair of type parameters. Please check out: 4.7.1. Writing new pair styles — LAMMPS documentation
