Dear Axel,
Dear Users,
I have compiled “user-meam” package with “intel_cpu_intelmpi” on a SMP system. It was compiled without any error. I ran tests with OMP_NUM_THREADS=1 and “mpirun -np …” without any error. In this case, all core were used.
it is USER-MEAMC.
It was typo. sorry. I used USER-MEAMC
However, whenever I used OMP_NUM_THREADS=xx, and use lmp_intel_cpu_intelmpi without mpirun command, only one core is used. Other packages such as “molecule” ran with openmp without any problem.
I think openmp on SMP is faster than mpi. So, any help is appreciated.
a) you are thinking wrong. with domain decomposed MD codes, using MPI,
especially if a software like LAMMPS has been built from ground up to
efficiently do MPI parallelization, is usually more efficient or as
efficient. in LAMMPS multi-threading is added after the fact and there
are multiple issues with performance.
Thanks for your information about LAMMPS. With other codes such as LATTE (with intelmpi/mpiifort), I got faster time when I simply used above strategy (setting OMP_NUM_THREADS to total core) on SMP. I am not sure, but I think MPI is the best case for clusters with distributed memory. At least for some other codes OMP is better for shared memory systems.
b) in LAMMPS using multi-threading requires using specific
multi-threaded styles. there are three different packages with thread
support (and different requirements and strategies). please review
https://lammps.sandia.gov/doc/Section_accelerate.html for more
details.
Thanks for your information.
c) because of b) simply setting OMP_NUM_THREADS doesn’t do anything.
d) there is no multi-threaded version of USER-MEAMC
I guessed that USER-MEAMC doesn’t use openmp, but I was not sure. Thank you.
