Hello, everyone
Recently I am learning a user-package called OCTP. https://github.com/omoultosEthTuDelft/OCTP
I found that if I use OCTP with loop structure like,
variable i loop 0 2
fix 3 all ordern diffusivity {Nevery_ordern} {th} c_0 file diffself-{i}.log diffonsager-{i}.log
run 100000
clear
next i
jump SELF
it will only generate the result for i=0 and shows the error and stops. No result for i=1,2.
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 2124 RUNNING AT q16copt057.crc.nd.edu
= EXIT CODE: 11
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
I think this problem comes from the memory usage when running with mpi.
Could anyone give me some instructions so that I can fix this error and run it on multiple cores?
Thank you very much.
Xiao Zhao
