I wrote a command computer euler/chunk which is similar to compute inertia/chunk and could calculate spin axis vector and three Euler angles of molecules. The compute runs well with command fix ave/time such as the bellowing.
compute moleuler all align/chunk molchunk 1 2
fix moleulertime all ave/time {Ne} {Nr} ${Nf} c_moleuler file wat.euler.time mode vector
The compute command outputs nchunk*6 array. The first three columns are spin axis vector and the last three is Euler angles(alpha, beta and gamma).
However, when I use the following to calculate the history of {spatial average cos(beta)^2}, I encountered the error "Invalid special function in variable formula. I think it’s a simple problem but I couldn’t find the error. Hope some one could help me. Thanks in advance.
variable molcos equal cos(c_moleuler[5])
variable molcoss equal ave(v_molcos^2.0)
fix moleulerspace all ave/time 1 1 1 v_molcoss file wat.euler.space mode scalar
Han
bellowing.
fix moleulertime all ave/time \{Ne\} {Nr} ${Nf} c_moleuler file
variable formula. I think it's a simple problem but I couldn't find the
what is the point of using "ave()" here? molcos is an equal style
variable and thus would return a global scalar
also ave() takes exactly one argument, not an expression.
the error message comes from the latter issue.
moleuler is a compute which outputs a global array(size is # of chunks*6)
molcos is a global vector(size is # of chunks)
I hope to make average of molcos and get a scalar. Maybe I shouldn’t use equal style here?
Thanks axel
