Hi there,
I am currently doing a granular simulation where i want to give impulsive force to my bottom layers of grains. In order to do so i have created a region contaning only the bottom granular layer & grouped them. When i use add force command all i can see is that layer gets deleted or vanished somehow from the system.
I want some help regarding this.
i am also providing my code later of the code for this.
The code is
Define the bottom layer region (adjust height based on grain diameter)
variable layer_height equal {d1} # Height of the first layer region bottom_layer block 0 {boxx} 0 {boxy} 0 {layer_height}
Group for grains in the bottom layer
group bottom_grains region bottom_layer
Apply impulsive load to only the bottom layer of grains
variable force_magnitude equal 300.00
fix impulse bottom_grains addforce 0.0 0.0 ${force_magnitude}
Run the simulation briefly to apply the impulse
run 26
Remove the impulse force
unfix impulse
Continue running to observe the behavior after impulse
run 20000
