Hello:
I am trying to use maps with "c=0", i.e., assuming the same computational cost for all structures, no matter their size.
However, maps gets stuck in finding the next structure when doing so. I thought maps chose the next structure based on the gain:
G_i = tr[…] / C_i
where tr[…] is the trace of an expression involving the design matrix X (columns are correlation functions) of what has been seen so far, and a candidate structure i, and C_i is the estimated cost of structure i which, by default, is N_i^3 (where N_i is number of atoms in the unit cell of the structure).
There should not be anything wrong with using N_i^0 = 1 ? In this case, we simply compare the variance reduction of structures without accounting for their relative costs.
I think this is what happens:
Maps stops looking at structures with larger unit cells when:
V_max / C_i < G_max
where G_max is the largest gain seen so far. V_max is the theoretical upper limit to the gain.
But if C_i = 1 we are only stopping if any of the structures seen so far has a gain value larger than the theoretically possible value? But this rarely happens I think. I am not even sure a "<=" would help either (it would make things better, but not guaranteed to work). What I mean is, it can be tough finding the structure with exactly the largest possible gain.
Maybe there should be some user-defined threshold of the theoretically largest possible value (in the case of no cost)? Such as "when the max seen pool has 80 % of the largest possible, stop".
In any event, the conclusion seems to be that maps, in its current implementation, cannot run in a mode that assumes no computational cost of structures. I would love to hear that I am wrong about this.
Finally, I understand that maps should have a tough time using c=0 because I am asking for the correct ground state line among an infinite set of structures. At least c>0 limits the search in its restriction to smaller sized structures. But there could be scenarios where you want c=0 and then maybe have some other means to restrict the search (such as the proposed 80 % user defined threshold).
Any thoughts?
