Hi! I’m trying to determine the effect of a vacancy defect in an otherwise perfect aluminium cube with increasing amount of vacancies.
To create this cube I first create a perfect block, and then replicate it multiple times, however I had an issue with my call of the delete_atoms function as I was directing it to a group-ID instead of a region-ID, as directing it to my region-ID would make it delete only the first atoms, in a similar fashion as this other instance : https://lammps.sandia.gov/threads/msg63123.html
Would there be a way to use delete_atoms on my group created after calling replicate?
Thank you very much!
suffix omp
package omp 12
variable lattconst equal 5
variable repetition equal 10
log Al_grain_30.log append
---------- Initialize Simulation ---------------------
clear
atom_style atomic
atom_modify map array
---------- Create Atoms ---------------------
lattice fcc ${lattconst}
region box block 0 1 0 1 0 1 units lattice
create_box 1 box
lattice fcc ${lattconst} orient x 1 0 0 orient y 0 1 0 orient z 0 0 1
create_atoms 1 box
replicate {repetition} {repetition} ${repetition}
---------- Define Interatomic Potential ---------------------
pair_style eam/alloy
pair_coeff * * Al99.eam.alloy Al
neighbor 2.0 bin
---------- Run Minimization ---------------------
group cube type 1
delete_atoms porosity cube 0.1 420
timestep 0.001
fix 1 cube box/relax iso 0.0
thermo 100
thermo_style custom step temp enthalpy press cella cellb cellc
thermo_modify flush yes
thermo_modify norm yes
min_style cg
minimize 1e-25 1e-25 5000 10000
fix 2 cube npt temp 1000.0 1000.0 0.1 iso 1000.0 1000.0 0.1
variable iterations equal 10000
dump mydump all xyz 1000 C:\Bin\LAMMPS\Exo9[dump5.xyz](http://dump5.xyz)
run ${iterations}
print “All done!”
