Hi lammps users,
I am currently trying to model a system of solvent under external electric field. I am using OPLS-AA force field and NVT ensemble. The system is 100 methanol molecules and the simulation box is cubic with box length as 18.87 angstrom. However when I use 0.1 V/angstrom electric field, the simulation box expands dramatically and obviously it destroys the constant-volume limitation. So could anyone kindly help me check the input file? Many thanks!
The following is my input, and my data file is also attached.
units real
neighbor 2.0 bin
atom_style full
bond_style harmonic
angle_style harmonic
dihedral_style opls
improper_style cvff
pair_style hybrid lj/cut/coul/long 12 12
pair_modify mix geometric
kspace_style pppm 1e-5
special_bonds lj/coul 0.0 0.0 0.5
read_data data.lmp
pair_coeff 1 1 lj/cut/coul/long 0.030000 2.500000 # H00 H00
pair_coeff 2 2 lj/cut/coul/long 0.065999 3.500000 # C01 C01
pair_coeff 3 3 lj/cut/coul/long 0.030000 2.500000 # H02 H02
pair_coeff 4 4 lj/cut/coul/long 0.030000 2.500000 # H03 H03
pair_coeff 5 5 lj/cut/coul/long 0.170000 3.120000 # O04 O04
pair_coeff 6 6 lj/cut/coul/long 0.000000 0.000000 # H05 H05
fix SHAKE all shake 0.0001 20 0 b 1 2 3 5
velocity all create 298 298 dist gaussian
thermo_style custom step cpu etotal ke pe evdwl ecoul elong temp press vol density
thermo 1000
fix 1 all nvt temp 298 298 100 tchain 3 mtk yes
fix 2 all deform 1 x final 0.0 18.87 y final 0.0 18.87 z final 0.0 18.87 units box
run 10000
unfix 1
unfix 2
timestep 1
fix 8 all nvt temp 298 298 200 tchain 3 mtk yes
fix kick all efield 0.10 0.0 0.0
restart 10000 MeOH-NVT-E1.restart1 MeOH-NVT-E1.restart2
dump d1 all custom 10000 traj-MeOH-NVT-E1.lmp element xu yu zu
dump_modify d1 element H C H H O H
dump_modify d1 sort id
run 10000000
undump d1
unfix 8
data.lmp (125 KB)
