I have a doubt regarding the use of fix npt with long range Coulomb Interaction.
I am simulating a polymer-water system where I am using fix npt to change the pressure few times during the simulation.
Below is a portion of my input script which does this job:
NPT at 0.5 atm
log cycle_1_npt_0.5
fix 1 all npt temp 400.0 400.0 5.0 iso 0.5 0.5 1000.0
run 500000
compression from 0.5 to 1.0 atm
log cycle_1_compression_0.5_to_1
unfix 1
fix 2 all npt temp 400.0 400.0 5.0 iso 0.5 1.0 1000.0
run 500000
I have run this earlier with an older lammps version (18 Jan 2011) and things were pretty fine.
Now while I am running the same thing on another machine with a newer version of lammps (17 Oct 2012), I get problem with pressure, Ecoul and Elong at the end of one run and the beginning of the other, rest all thermodynamic output remaining the same as expected. I am using “kspace_style ewald 1.0e-4” for long range Coulombic interaction.
Below is the themo output for the end and beginning of fixes:
End of fix 1:
Step Temp Press Volume PotEng KinEng TotEng E_vdwl E_coul E_long E_pair E_bond E_angle E_dihed E_impro E_mol CPU
500000 395.82769 536.24633 32096.629 -5131.664 2981.5748 -2150.0892 -755.93059 -687.33008 -8134.3703 -9577.631 1077.101 1903.8957 1220.2378 244.73247 4445.967 2945.0038
Begining of fix 2:
500000 395.82769 521.75017 32096.629 -5134.0405 2981.5748 -2152.4657 -755.93059 2270.395 -11094.472 -9580.0076 1077.101 1903.8957 1220.2378 244.73247 4445.967 0
The Ecoul and Elong are changed by almost same amount, so that the net potential energy is nearby the last value. Sometimes, in a later stage of simulation, the change is in decimal places, as below:
End of one fix:
1000000 401.23223 827.41872 31193.493 -5240.6336 3022.2845 -2218.3491 -791.75238 2257.482 -11098.919 -9633.1893 1066.0763 1847.8487 1225.0291 253.60156 4392.5556 816.22427
Begining of the other fix:
1000000 401.23223 827.6165 31193.493 -5240.6314 3022.2845 -2218.3468 -791.75238 2272.4813 -11113.916 -9633.187 1066.0763 1847.8487 1225.0291 253.60156 4392.5556 0
Also, I can see change in Ewald parameters ( G vector, RMS force accuracy, and relative force accuracy).
I came across the below mail thread(3 years old) which highlighted a similar problem. It was suggested told to be “the way LAMMPS adjusts the grid to
achieve the specfied accuracy” but later was found to be “a bug with fix box/relax and long-range Coulombics”.
http://lammps.sandia.gov/threads/msg12047.html
I am not using fix box/relax and also I hope that bug must have been fixed in the later lammps versions.
Could you please suggest if this is an allowed kspace grid adjustment by lammps or still a bug. As I have already ran this in an earlier version without any problem, I doubt if the newer version has some issues.
Any suggestions will be really appreciated.
Thank you so much in advance for your time and support.
Madhu.
